It appears there is NO set code for the height of an electric box (outlet/switch) in basement. (Not really one for main floor either.) It seems 48" is pretty much standard but I've seen ranges from about 24" to 55". Also It appears current code in US is ALL outlets in basement MUST be on GFCI (with exception of sump pump which must be on single outlet on breaker by itself). (With codes pending requiring spark arrestors. (What a pain.) I have had to put my water softner and updated electronic control (gas) water heater (with circulating pump) on standard outlets as they keep blowing GFCI.
I certainly understand why you would want GFCI in basements that have damp floors etc (especially with bare feet). I have drain tiles running almost a foot below the basement grade (I live on a hill so all water drains, Although I have sump pumps built in they NEVER run!) I don't even need a dehumidifier (house was built in 2009) (also have radiant floor heat). What makes my "basement" any different than a bi-level, tri-level or for that matter a house build on a concrete slab? They probably have more of a damp floor than I have! (p.s. No carpet or tile, just epoxy paint.)
Thanks
Daryl
Thanks
Daryl
