Hi all,
I am looking at a blue print that has a panel schedule with a demand calculation for commercial office space. I have two questions:
1. They have treated the bathroom exhaust fan as a motor load, applying the 125% rule. I come from an industrial background and we always treated devices with motors under .5 Hp as regular loads but I can't find anything in the code to support that. It may have been that most of the time there were larger motors involved. Does anyone know if there is a min size motor?
2. The panel schedule has the demand VA for each single phase circuit listed. They calculated the phase imbalance using the VA numbers which is fine, but I need to add a 3 phase device (steam humidifier) to the panel. Do I just divide the listed VA in 3 for each phase or do I use Pp=Vp*Ip? They come to almost the same number but I want to know the right way. In the past I always used current to calculate the imbalance.
Thanks,
Chris
Thanks,
Chris
