Elliott I am new to forum. Have been wiring for 30 years. Just had inspector say that fan within. 3 feet if tub needs to be protected. Thanks
That's expensive. I just feed it from the GFCI receptacle that is already there.I have had a couple inspectors tell me this, and it has been implied on manufacturer suggestions plenty of times. It's easier to just throw that circuit on a GFCI breaker and not argue.
You may not be able to if the bath circuit is used in other bathrooms.That's expensive. I just feed it from the GFCI receptacle that is already there.
What is a red staple. I use the regular staples for 2- 12/2 NM cables. I would think if the cables were round there would be an issue with the standard size staples.Ok thanks I d never heard of it either. He also said 2 cables on top of each other required red staple. Had nt heard of that either. He must have own code book.
Sure, if you are already sharing that circuit and it's already fed from the receptacle.That's expensive. I just feed it from the GFCI receptacle that is already there.
What the heck is a red staple? For many more than 2 wires, he could be referring to the use ofOk thanks I d never heard of it either. He also said 2 cables on top of each other required red staple. Had nt heard of that either. He must have own code book.
This statement would be correct if you changed out "a few limited circumstances" for "the overwhelming majority of the time".But yes, there are a few limited circumstances for small bathrooms where your suggestion is perfectly valid.
What code are you under?You can t just throw it on gfci breaker cause now it s gotta be afci also ugh
I call them stackers- they take 4 wires. A stapleRed staple. Little bigger then blue has red insulation
Massachusettes is under 2014What code are you under?
They don't waste time! :001_huh:Massachusettes is under 2014
More 1814, pilgrim hats, the occasional witch burning, etc.....Massachusettes is under 2014
because lord knows our tax $$$ goes to politically correct stapalage first & foremost !:jester:He's probably technically correct on the staple but again nonsense.
