I already have a total of 5 bathrooms just for 2 floors
Don't know about CEC but if they tried that on me I would fight it and have the inspector show me where it is in the NEC. They can't just make up their own rules. The job(inspecting) is tough enough so why aggravate things with stuff that doesn't existThe manufacturer of one we installed did not require a gfci, however the inspector made us install one.
True, except that with the NEC being a minimum standard and the inspector having discretion as an AHJ, they get away with itDennis Alwon said:Don't know about CEC but if they tried that on me I would fight it and have the inspector show me where it is in the NEC. They can't just make up their own rules. The job(inspecting) is tough enough so why aggravate things with stuff that doesn't exist
Only if you let them. They are the authority having jurisdiction but they are not suppose to enforce codes that are not there.True, except that with the NEC being a minimum standard and the inspector having discretion as an AHJ, they get away with it.
That probably would not be a good idea. Any leakage current would be additive from all connected loads and nuisance tripping would be more likely on the feeder breaker for the sub-panel.It would be nice if I could land a 125 amp GFCI protected sub and cover everything including the Hot Tub outside behind the bathroom on the deck.
I pick my battles best I can, didnt loose money over it so saving an argument for one that does.Only if you let them. They are the authority having jurisdiction but they are not suppose to enforce codes that are not there.
