Hi, im working on a new project that would require a PLC with atleast 20 output and 20+ input also. If possible something from Allen-Bradley or Schneider.
The closest i found was a micrologix 1000 with 32 IO
That project doesnt really need anything very complex and my budget is prety limited also. No analogic output or input is required for this project and will all be done with 24vdc
Would you consider buying something like a SLC 500 with enough Input_output slot ? or simply buy 2 PLC like micrologix 1000 ? or is there any other brand not so expensive that give us the possibility to add extension IO to them ? if possible i would prefer them with rslogix 500 or ZeliosSoft 2 for programming tool.
