I just finished one and used tiger boxes. A few of course I had to put a bracket box and mud ring on.I hardly ever do renos on houses old enough to have lath and plaster but I'm doing one right now.
I normally use F-clips but they won't work on walls this thick. What's my Plan B?
Just screw the backing into place thru the plaster/lathe. Two little drywall screw heads are simple to patch/fill.I think I'll make my hole and then get the GC to glue a 2 X 2 inside the wall beside the box with some PL400.
If you are using romex, the clips on these are are plenty deep for lathe/plaster. Slater brand.
Really? I've never seen skinny studs in old houses around here. I have run across them one time in an early production model early 60's era house.The only problem with the Slater boxes is depth inside the plaster walls sometimes they are too deep.
We just screw right through them into studI've been using those for years on plaster lath, they work great for switches. For receptacles we always cut in right alongside a stud. This way you can use a "Smart Box" and screw it right to the stud.
I had one a few months back it was 2"x3"s but with the plaster and lath depth it almost fit. I had to give the fingers that met the back of the box a little persuasion with my multi-master.Really? I've never seen skinny studs in old houses around here. I have run across them one time in an early production model early 60's era house.
Around here lath and plaster houses have real 2x4's.
Persactly. Many interior (non-load-bearing) walls were built with the studs "sideways" to increase usable space. Makes it difficult to use any kind of deep box when adding wiring later on.Around here alot of interior walls are turned 2x4 walls.
I have been using a rotozip with tile bit to cut out the plaster and then the wood bit to cut the lathe behind. Keep the vacuum handy because its a little messy. I do it this way in order to not crack the plaster. I use what ever depth metal old work box will fit, deeper the better. I use a small bit to predrill for small woodscrews so the lathe won't split.
