1 - 20 of 30 Posts
What do you consider the best skill set for a well rounded electrician.
For me
Learning to bend conduit.
Residential wiring
Trouble shooting skills I learned doing residential and light commercial service.
If you can do this you can work in almost any aspect of the trade.
Senile Member
Well.. Basic skills required-
Thread and bend 6" rigid galv conduit and install 600 ft per day
Run miles of 4" pvc per day for below slab.
Create your own inventions using radio tubes.
Begin all thread posts with Well...
I learned this basic skill set from Mr. Pipebender.
I own stock in FotoMat!
Understanding prints & spec books.
Organizational skills.
Overseeing, or working with, others.
Understanding the other trades.
Working knowledge of Codes, and not just the NEC.
Being able to see past the task at hand.
Trolling internet electricians' forums.
Ability to figure what color to install on a 480/277v system for circuit no. 37...........in your head.............. quickly.
IBEW L.U. 1852
For me
Residential wiring
All very good and important skills for a well rounded sparkie. I would add having even a rudimentary knowledge of PLC's and motor controls. Even the most basic of knowledge in those two things can and will help you immensely in your career.
Figuring any color for any circut number in your head should be easy when you know the color coding scheme to start with.
We all know there are lots electricians out there who can't do it though.
Estwing magic
The best electrician can figure things out even if he has never done it before. The best contractor, like someone else said, makes excessive amounts of money.
Retired Account
For me
Residential wiring
If i had to pick one , it's be TS'ing
Seen some amazing sparkies, read even more here.....
Senior Moment
Ability to tell tall tails without slowing down task.
Internal clock set to lunch and breaks.
Able to unwind at tavern after work without making ass out of himself and not upset the ladies.
Donuts > Fried Eggs
I was good right until the last one. I can not make an ass out of myself or not upset the ladies, but I can't do both at the same time.
Chit, how do you do this again? Divide by 6 and then count the remainders on brown, orange, yellow?
IBEW L.U. 1852
Pretty much..........anything evenly divided by 6 is on the "C" phase as well as the circuit across from it. Count one way or the other from there.
1 - 20 of 30 Posts
