Best wiring setup for a 240V 30amp circuit (mix indoor/outdoor)? Sauna heater
251 Views 2 Replies 3 Participants Last post by  MikeFL
I need to install a new 240V 30amp circuit for outdoor Sauna heater. Wires will come out Panel in my garage, into the attic, run 100ft to the back of the house and come down through the soffit inside a PVC conduit along the outdoor wall until its final box by the Sauna. Manufacturer recommends 8 gauge for this distance.
I installed circuits and wire before, I think I can do this, but I want to double click on the best cable/wire setup - Options in my mind:
  1. Romex 8/2 - I see Romex in my attic, I don’t have a rodent problem apparently, but how does one migrate the Romex into the final conduit going outdoors through the soffit? I understand conduits need to be sealed on both ends.)
  2. Metal Clad 8/2 – Would see to provide better protection in the attic, but again, can I just insert the metal conduit inside the final outdoor conduit?
  3. THHN 8AWG wire going through PVC conduit all the way from the panel to the outdoor box - Seems straight forward but it will be a massive pain to install by myself.
Trying to balance adherence to code but not make it twice as complicated for me.
Thanks!!
Status
Not open for further replies.
1 - 3 of 3 Posts
My local code requires metal conduit with a ground wire for all pools/spas.
What does your local authority say?
Thanks for posting on ElectricianTalk.com, the premier online forum exclusively for professional electricians.
Please understand that working with electricity can be unsafe and even deadly if not done by a qualified professional electrician.
  • Electrical hazards cause more than 300 deaths and 4,000 injuries each year in the U.S.
  • More than 3,500 people die in fire every year in the US, most in their own home where we expect to be safest.
The moderators of this site strongly suggest you contact a professional electrician in your area.
That being said, if you are permitted by law to do your own electrical work, you may visit our sister site www.DIYChatroom.com, the premier online forum for Do It Yourselfers, where we also have an Electrical section and plenty of pros to assist.
We apologize for any inconvenience this may have caused.
This thread is now closed.
1 - 3 of 3 Posts
Status
