Anybody have a rough number on a 5500 sq ft house? In RI, 400amp underground/house does have gas/55 recess cans/ standard spacing of outlets nothing crazy/ homeowner to supply alll lighting fixtures other than recess.
$47,374.03..Anybody have a rough number on a 5500 sq ft house? In RI, 400amp underground/house does have gas/55 recess cans/ standard spacing of outlets nothing crazy/ homeowner to supply alll lighting fixtures other than recess.
You want the meter main in this case.100' of wire in 3 inch pvc (6 cuts of 250 al), not responsible for digging trench. 400 amp meter socket feeding two 200 amp panels. Thinking i might have to buy meter socket with disconnect outside because panels will be on other side of house. Got a quote for that meter at 1500$ vs. 375$ for regular one. May just put two disconneccts in basement. Problem is its a finished basement, not sure how homeowner will feel about that.
Use your own numbers, make sure include all of your costs and markup on stock.Wow I was way off, I came up with 22k. Glad i asked. Im new to the bidding game, nevermind resi work. Thanks
Just out of curiosity, how did you get to 22K?Wow I was way off, I came up with 22k. Glad i asked. Im new to the bidding game, nevermind resi work. Thanks
Exactly, big custom homes you have no idea how many call backs you can expect.Detail EXACTLY what you're responsible for to the last wood screw. Anything beyond that must be signed off with change orders. Make your bid "Subject to site conditions". If the job is a mess at least that gives you some justification to charge more. Big houses can be a disaster. I oils never do another one without completely covering my ass beforehand.
Depends on the home owners... a small 3000sqft house can easily have twice the number of call backs than a 10,000sqft house. Because the home owners are nuts.Exactly, big custom homes you have no idea how many call backs you can expect.
" Uhmm, there must have been some misunderstanding, i wanted to switch that one cieling fan, lights and fan separate, from nine locations, also, i'm allergic to remotes."Depends on the home owners... a small 3000sqft house can easily have twice the number of call backs than a 10,000sqft house. Because the home owners are nuts.
Prostituting that sense of entitlement and ego is just too easy....It's been known to happen on the smaller houses too but the bigger houses are typically owned my really wealthy people that think they're doing you a favor by giving you the work.
Chicken, i've seen your boats.Prostituting that sense of entitlement and ego is just too easy....
30K usually equates to
another 10K for anything you whine about
$10 per sf.Anybody have a rough number on a 5500 sq ft house? In RI, 400amp underground/house does have gas/55 recess cans/ standard spacing of outlets nothing crazy/ homeowner to supply alll lighting fixtures other than recess.
