I don't know what kind of prices you get but my price is a lot cheaper for the 54 space w/po neutral versus the standard 60 space panel.54 spaces? 60 spaces? I have not seen these.
I was told its for handicap accessibilityjbfan said:Why? Are you guys vertically challenged?:jester:
Lol. I think I hit the wrong button. Is this Electric Talk or the **** thread?....... You are the bestest electrician ever.
Thanks :thumbup: :laughing: I don't get into residential often enough to know what's a big panel or large run of wire or that kinda thing for that line of work :no:...... You are the bestest electrician ever.
omg!40 circuits is a 'big ass panel' ? Must be residential. Been working on 114 circuit panels all this week :whistling2:
What size of a building needs 114 circuit panels? Are they all located in different areas? Are all 114 panels the same brand?40 circuits is a 'big ass panel' ? Must be residential. Been working on 114 circuit panels all this week :whistling2:
I bought a Homeline 20/40 and a QO 30/40 last year from Lowes. They were both clearance items and I'm finally going to use them. So with the opportunity cost of having my money tied up for a year I'll only be losing $125.00:laughing:In new construction I use a 40 space(never a 32/40) and add a sub in the garage or utility room. Seems to work well.
I take it these are sub-panel you're installing. What brand? I've use NQ's but not that many circuits in one panel.Installed one in a grocery store to feed there deli, hot food counter, and pharmacy. Pretty sure we loaded it up to.
Pretty close to all 120v circuits. In my case it's a service upgrade/renovation with limited space for a panel. I need at least 50 ckts.how many AFCI breakers are required these days, in new houses? it better to use AFIC receptacles an a smaller panel or one big panel?
Lame. Real electricians install 114 circuit panels, all 480 volt.Pretty close to all 120v circuits.
You have to put a breaker in unless you run conduit to the first receptacle. You could get away with two, I don't think the HO would be too happy.Lep said:how many AFCI breakers are required these days, in new houses? it better to use AFIC receptacles an a smaller panel or one big panel?
A 34 storey condo building downtown. They are all in electrical rooms, 2 or 3 electrical rooms per floor in general. Usually with 2-3 114 circuit panels and a couple smaller 60 space or something panels then the lighting automation panels. All of these panels are spec'd and are the same brand, 120/208 3 phase with isolated ground.What size of a building needs 114 circuit panels? Are they all located in different areas? Are all 114 panels the same brand?
So badass!!Lame. Real electricians install 114 circuit panels, all 480 volt.
