What would cause a 240V/24V transformer to blow in a air handler for a heat pump?
I'm going to break the 2 sentence rule here to add the details.
I'm not an HVAC guy but I was asked to look at the thermostat wiring for a heat pump. The customer tried to replace his thermostat and thought he might have broken a wire when changing it. So I agreed to check that for him.
The wire was good so I thought I would look in the manual for the new stat to see if he had it wired right and programmed. First thing I saw was it said the stat was not for a heat pump. So I picked up a new one that was for a heat pump.
I installed it and turned the power on and nothing worked. So I went to the air handler to see if there was a fuse blown or anything obvious. I checked the secondary side of the transformer and didn't have the 24V.
I then checked the primary side and didn't have the 240V either.
The AH had two 60A feed through breakers and one of them was bad. So I picked up a new one and installed it. Still nothing worked, so I checked the secondary side again and still no 24V.
I figured the transformer probably had went out while the guy was trying to get the stat to work. He said he had been swapping wires around. Anyways, I picked up a new transformer and installed it. Still nothing worked. I checked the primary and secondary. I had the 240V, but no 24V.
I thought maybe I got a bad transformer so I took it back and swapped it.
I checked it this time with no loads connected. I had the 24V. I then went back to the stat and checked the wiring according to the manual and everything looked correct.
I hooked everything back up and still nothing.
Checked the tranny again, no 24V!
It blew the transformer again.
I told the guy to call an HVAC guy and I wished I had told him to do that to start with. If I hadn't known the guy I would have passed on the job to start with.
Any ideas on what is blowing the transformer?
