standard practice is to bond at transformer
I just assume most people don't understand correct grounding/bonding procedures for separately derived systems.Chrisibew440 said:I say that, because everybody wants to jump to conclusions that its bonded twice because around here it's typical to see it in the tranny.
....standard practice is to bond at transformer IMO, rarely see it the other way.There is no standard practice, and no one freaks out about it here. It should be up to the installer how they do it. I almost always do it at the secondary panel because it keeps the transformer less cluttered and it's extremely simple to pipe out the top of your panelboard to hit your building steel
Agreedponyboy said:I just assume most people don't understand correct grounding/bonding procedures for separately derived systems.
And for me standard practice is to do it at the panel. I never see it any other way360max said:....standard practice is to bond at transformer IMO, rarely see it the other way.
I assume nothing.I just assume most people don't understand correct grounding/bonding procedures for separately derived systems.
which in my case is typically 30' above the paneldon_resqcapt19 said:At the location that is closest to the grounding electrode.
...I work industrial and I have yet to see a 3ph 480v transformer that feeds a 208v panel, bonded at the panel. BTW, the job I'm currently on probable has 500 transformers at a minimum , all 480v primaries, all bonded at TF.And for me standard practice is to do it at the panel. I never see it any other way
You know I'm in industrial as well and transformer installations are kind of my bread and butter. I do about one a week if not more. I simply found a method that works for me and I'll continue to do so. The NEC gives us the option so it's ignorant to say one method is more correct than the other.360max said:...I work industrial and I have yet to see a 3ph 480v transformer that feeds a 208v panel, bonded at the panel. BTW, the job I'm currently on probable has 500 transformers at a minimum , all 480v primaries, all bonded at TF.
I'm struggling trying to envision this to be honest.Phatstax said:Has anyone seen a grounded secondary conductor run continuous thru XO lug and then looped around and bonded to XFMR grounding lug unbroken? I had some old schoolers show me that a few times. When I've done it recently my freshly turned out foreman always has me change it. I have not seen it done in awhile. Is this an outdated wiring style or just plain wrong? Of course building steel and pri and sec GEC were installed as well. Please talk amongst yourselves.
Perhaps because you are used to dealing with much larger wire or parallel feeds on a lot of your projects. I'm talking about feeding 200-400 amp panels in commercial and light industrial. Much smaller wire than you might normally deal with. Or, maybe I didn't describe it well.I'm struggling trying to envision this to be honest.
