We have a client with chronic low voltage problems.
Right out of the vault we have just about 205 volts.
The POCO insists that it is within what they are allowed to provide so, that about all we are going to get from them.
They have lost a couple of three phase heat pump type pool heaters over the last few years and the equipment supplier said that was it for warranty unless the voltage was brought up a bit.
No problem, just a nice couple of boost transformers and we should be OK.
I went onto SquareDs website and rilled down to the Buck/Boost page and found the calculator.
I used 200 volts in with 22 KW as the load and they gave me the BOM and the wiring diagrams.
I was expecting to see two transformers but, they are giving me three.
Would I be incorrect in thinking that I could go WYE/ Delta and just use two transformers?
http://www.buckboostcalculator.com/index.cfm
