1 - 5 of 5 Posts
Swimmer
I am referencing the 2014 NEC
For Power Limited Fire Alarm (PLFA) Circuits, 760.121(B) says "The branch circuit supplying the fire alarm equipment(s) shall supply no other loads."
For Non-Power Limited Fire Alarm (NPLFA) Circuits, 760.41(B) says "The branch circuit supplying the fire
alarm equipment(s) shall supply no other loads"
I have worked in several housing tracts that were originally built with fire alarms. None were on dedicated circuits.
These alarms were all of the type activated by a flow switch in the fire sprinkler plumbing.
What am I missing here? Are these common alarm circuits neither PFLA or NPLFA?
Non Power Limited essentially equals 120VAC bells triggered by a flow switch.
This circuit is integral to the Fire Alarm logic.... yet has full access to 120VAC. ( It's a legacy device. There was a time when such bells were powered by water flow -- directly. )
The intent of the Code is to stop folks from turning off the F/A system by way of un-powering it unwittingly.
Swimmer
What NEC version were they installed under? The dedicated branch circuit requirement is a relatively recent change, either 2008 or 2011.
EDIT: It's the 2008 version.
Thanks Fishbulb. I'll look up the change in the change in the NEC. The newer homes may have been built before 2008. I'll make a note to check next time I'm in a newer home.
1 - 5 of 5 Posts
