Thoughts on cause? Only seems to have affected top of the bar bottom was fine. None of the terminals seemed loose.
loose connectionThoughts on cause? Only seems to have affected top of the bar bottom was fine. None of the terminals seemed loose.
Are you experienced enough to determine if it could possibly be a poco problem? I'm not trying to put you down either , I just have no idea how much experience you have troubleshooting.bav_21 said:Also it was like the bar itself heated up one of the wires insulation was touching the top of the bar and it had a bit of melting at that point
The bar did heat up from one or more loose connections. Cut back the damaged wires and replace the bar or the problem will keep coming back.Also it was like the bar itself heated up one of the wires insulation was touching the top of the bar and it had a bit of melting at that point
Loose connection or over tightened.Thoughts on cause? Only seems to have affected top of the bar bottom was fine. None of the terminals seemed loose.
What is "GOMB"? :001_huh:Loose connection or over tightened.
........What is "GOMB"? :001_huh:
I like that:thumbsup:, I got one to apply to the Jersey crowd, LMN.:laughing:........
