Does anyone know if is ok to build walls/ceiling around a 480vac bus duct system as long as access is provided to the bus plug disconnects by removing ceiling tiles?
For example, just remove a ceiling tile if the bus plug disconnect needed to be locked out?
Thanks
Thanks
