Did u really du dat?:001_huh:Seriously, can i du dis ?
Oh yeah, i sure did. have any other ideas 2 hrs from drywall time, 1 hr to nearest hd, and pulling thwn from outside pvc to carlon box?Chris1971 said:Did u really du dat?:001_huh:
Yes. Do an electrical apprenticeship to learn how to wire things correctly.Oh yeah, i sure did. have any other ideas 2 hrs from drywall time, 1 hr to nearest hd, and pulling thwn from outside pvc to carlon box?
Why would i wanna do that ? Its done, gonna be covered, and pretty sure the house wont explode and most important i got paid.MTW said:Yes. Do an electrical apprenticeship to learn how to wire things correctly.
356.42 Couplings and Connectors. Only fittings listed for use with LFNC shall be used. Angle connectors shall not be used for concealed raceway installations. Straight LFNC fittings are permitted for direct burial or encasement in concrete.Awg-Dawg said:356.42
Ive always been like that. Do first , ask questions later type. Btw , why can you bury a straight lfnc fitting but not sn angled one ???Calebxx12 said:Looks like you already did it, why ask... haha
Usually because you can easily run a fish tape through a straight fitting and repull wire if necessary. Ever tried that with an angle fitting???Ive always been like that. Do first , ask questions later type. Btw , why can you bury a straight lfnc fitting but not sn angled one ???
I can easily get a wire through 2.5ft of sealtight with a 90 . Vacuum, balll, string worst case. Is that the reason for that lame ass rule???Rollie73 said:Usually because you can easily run a fish tape through a straight fitting and repull wire if necessary. Ever tried that with an angle fitting???
Do you even own a codebook?....... Is that the reason for that lame ass rule???
I think thats pretty obvious![]()
I'm pretty sure he admitted he didn't in a number of older threads.![]()
Your right, ive just posted 1000's of these off the top of my headRoger said:I'm pretty sure he admitted he didn't in a number of older threads. Roger
