1 - 13 of 13 Posts
Hey, I'm an Australian looking to become an Electrician in Alberta, Canada. I was wondering if anyone had been through the Red Seal test and could explain a few things before I apply?
First of all, will I need to do much research to pass? I know its 70% pass, but are the questions usually tricky?
Is it recognized nationwide, or if I travel to another province, will I need to re do an exam to work there?
And is there any place online I can download and/or study for the exam, like past papers or guidelines?
Cheers!
· Banned
The questions aren't particularly tricky, but they're not particularly easy either.
Red Seal is accepted across Canada.
There is an ESAT practice test you can purchase from CSA. It's maybe $100CDN and it has all the questions that they pick 100 from to compile the Red Seal exam. It's a lot of questions, but if you feel about 80% comfortable with the questions, you should be able to pass.
Good luck and welcome to Canada, eh!
Oh okay, awesome!
Will I need to take anything in like a calculator or anything like that? And them questions provided by the CSA are up to date pretty good? Might just buy that and study that till I know them inside out haha
hi there, could you please kindly help out me?
for this question,
- Calculate the minimum conductor size required for an installation where there are single conductor teck cables. The cables are run in parallel to supply a 400A non-continuous load, are directly buried and spaced 190mm apart.
I should use Diagram D8 or D17?
for this question,
Teck 90 is not shielded. I haven't used single conductor but I don't believe it is either. So that would make you d8.
Also the red seal is excepted everywhere in the country except Quebec.
EDIT: accepted
hello all,
I hope you are doing well.
could please help me with this Q? Please.
Two single-phase 600-120/240 volt, 25 KVA dry-type transformers are connected in parallel. Determine the size the primary and secondary conductors supplying these paralleled transformers. Use R90XLPE Cu.
i used 26-256, 1 &2.
I1= 25000 / 600 = 41.667
I2 = 25000/240= 104.167
I1= 25000 / 120 = 208.33
I2= 25000 / 240 = 104.167
according to 26-256 (2b) --> 125% (104.167 + 104.167) = 260.41
could you please help me figure out Primary one??
hello all,
Hi all,
could you please give me some tips,
hi again,
1. actually for this type of question :
What is the maximum size of time delay fuse permitted for a three-phase 100HP/230V SCIM?
2. Determine the minimum ampacity required for the feeder conductors and the maximum size of time delay fuse permitted for the following group of 230V, 3ϕ, SCIM.
i don't know how should find the ''maximum size of time delay fuse''.
keep looking for your tip,
thanks in advance
1 - 13 of 13 Posts
