Look here...Has anyone experienced a canbus error on a generac that won't clear?
I have had more than one or two Cannabis errors. But not on a Generac, and things always cleared after a few hours.Has anyone experienced a canbus error on a generac that won't clear?
The physical link is broken ignition module fails or reset the Nexus controller fails or reset
having the battery chargers 120 volt AC connected without a battery installed
a blown 10 amp ignition module fuse
a blown 25 amp system fuse
What generation is the unitSame problem. First call tech support said replace charger based on tests. Second call replace controller based on tests. Any other options?
If you have more than 4 cylinder you have oneGen 3 Nexus controller 45kw. 25 amp fuse tests ok. can't find 10 amp fuse, so no external ignition module?
thanks for quick response!
I am not sure what he is referencing. Unless he is talking about the activation code.I've only worked on one liquid cooled unit so far. I assumed that these came set up with those entered from the factory. Where it came into play was when you replaced the controller. Not the correct?
Been installing Generacs since 1997.Yours was a replacement?
