What is unusual about terminating
Okay, one of the flaws with high speed copper wiring is that the high speeds standardized are conducted in highly controlled environments with no flaws.
To achieve maximum speeds with low error in transmission, lots of attention must be paid to the installation and termination of cables. Little minor installation problems, like bending a cat6 cable too tightly can nullify your hundred foot run.
The biggest problem with copper wiring is in order to test your installation you need equipment that can sometimes cost more than a brand new car. Unfortunately, as installers, we have to deal with these problems.
Give this article a read, a lot of it is relevant to cat6 installations:
http://www.lanshack.com/cat5e-tutorial.aspx
My biggest cat6 recommendations:
-no zip ties EVER
-let cables flow without being constricted
-keep the manufacturers twists as close possible to the termination point. Do not untwist when installing a jack
-keep cat6 three feet away from power sources, intersections are undesirable but sometimes unavoidable.
Edit: cat5/cat5e was more forgiving than cat6 in installation practices
