Exactly.wcord said:Is he looking for FT6 rating or what? if its a house and you are not running inside the cold air joist lined plenum, whats the problem?
Here in MB, rule 12-010 has been relaxed to allow residential wiring to cross thru a plenum if it is constructed of combustible material, ie a joist lined plenum. Your guy is an idiotExactly.
Ok I'll call him an idiot tomorrow and hopefully everything goes smoothly.wcord said:Here in MB, rule 12-010 has been relaxed to allow residential wiring to cross thru a plenum if it is constructed of combustible material, ie a joist lined plenum. Your guy is an idiot
No. And if it was I would have separation/insulation in between as if it were a Romex.Hmacanada said:Is it coming in contact with the heat runs for duct work?
Let us know how well that turns out. rotfOk I'll call him an idiot tomorrow and hopefully everything goes smoothly.
No I have not, but I know exactly where this is going. Use bare and you won't have any issues where it is run. Might be less expensive also.Anyone ever had a problem with an inspector running an insulated ground to the water main in a house through wood studs?
Drywalled ceiling.
Time to get your knife out and make all visible insulation disappear. :whistling2:Anyone ever had a problem with an inspector running an insulated ground to the water main in a house through wood studs?
Drywalled ceiling.
