I just got done going through the Eaton CH panel catalog and can't find what I'm looking for. I'm looking for a split neutral kit or maybe an even longer neutral bar for this panel. This neutral bar is beyond maxed out.
These neutral bars have these plastic standoffs and I kinda want it to look factory.
As you can see there's plenty of room to take some the neutrals around to the other side.
Here's a picture I took at work the other day, you can see the split neutral in the back i know it's kinda hard to see. I think maybe that's a BR type panel?
Here's the drawing, all it shows for accessories are ground bars....hmmm. It shows it coming with the split neutral installed though... the guy who installed this panel is a hack
Here's the drawing, all it shows for accessories are ground bars....hmmm. It shows it coming with the split neutral installed though... the guy who installed this panel is a hack.
Also what's with these cable guys putting clips on the meter can for their grounds??? Theres a bonding bridge right below the panel. This is why I hate resi work
Another one of those parts that is not easy to find in the catalog.
Not remembering the size of the holes in the existing bar you could purchase one of these.
The pic is not all that clear where the copper lugs are to my old eyes. You will need to take some measurements to be sure that it will fit when the cover is on.
I also found this one. The numbers are different so I am guessing.
Shop Neutral Bar Kit, 200A, Unbonded By Bussmann (Eaton) (2A1908-1) At Graybar, Your Trusted Resource For Circuit Breaker Accessories And Other Bussmann (Eaton) Products.
www.graybar.com
Elliot Electric Supply is usually good at searches.
Electrical Supplies Distributor. Elliott Electric Supply is your local electric supply house. We Deliver Lower Cost, Quality Products, and Personal Service
@SWDweller thx for the reply. I'm suspicious that either one of those come with the insulated "flat bar" that runs between the 2 neutral bars. I couldn't find any pics when I googled those Cat. numbers.
I did find the cat number for the neutral bar with the standoffs just no tie between them. I wonder if I can use whatever size wire between the 2 neutral bars without "violating the listing".
There's gonna be a service rated ATS in the future so I need the neutrals and grounds separated.
they come in many BR panels that have a plug in neu bar on both sides
the insulated, flat connection bar goes beneath the bus and everything else
i used to cut them out to give me an already installed grnd bar once i bonded it
I might have one of those straps and a pair of plastic stand-offs.
