1 - 10 of 10 Posts
Modérateur
anyone know if the guts from a 200a panel will fit in a 30 cir can?
thanks
That is kinda iffy depending on what the 200 amp guts will fit in the exsting 30 circuit panel is. plus the main breaker conferation will be differnt as well.
I did see a retrotfit from CH which it will fit in almost any type of tub as long it is listed to fit in that type of tub.
Merci.
The CH kits are great. I used one about a year ago to replace an old kinney panel. It has rigid coming out of 4 sides and was recessed in a block/plaster wall. I had new feeders pulled and panel swapped in about 3 hrs.
I haven't, never had a need to so far.
I haven't looked into them, but ive heard guys on here post about them alot.
Lots of old 125 amp split mains around here. The 12.5" ones, where you'd have to take sawzall to the stud to get a new panel in.
I'd be interested in knowing how well these kits would be with changing these panels out (for more space) or to repair a burnt up buss bar.
1 - 10 of 10 Posts
