1 - 10 of 10 Posts
So my boss decided to put 3/4 in plywood underneath lift so the junction box is even with Sheetrock. Well, now they decided to add a medallion. Is this going to create a problem?
most medallions taper down in the middle and leave a space for the "cup" of the light fixture. I would think you would just need a longer fixture rod & longer screws
I don't know what kind of lift you're using, but we use Aladdin lifts, and there's plenty of adjustment to lower the box for varying celling thicknesses. The box is usually mounted to a price of 1/2" emt that fits inside of a price of 3/4". The support cable runs right through the box/pipe assembly.
yea it is the Aladdin lift...
just make sure the opening in the medallion is wide enough for the connection to be made . The aladdin lift can be adjusted so you should be able to get the box to the desired height.
The Aladdin lifts have a round fiberglass circuit board that acts a commutator on the end of the cable. It is connected to the chandelier wires and makes contact with a set of brushes inside the fixture box - which in turn is connected to the switch leg. That has to be properly adjusted for the overall finished thickness. You also have to install a collar lower the box so as not to expose the medallion to any possible arcing.
thank you for making my post more technical :thumbsup:
yea I'm afraid that is what is going to happen.there is about an inch gap between medallion and metal box.. I'm going to have to lower the box even with medallion. The sucky thing is that lift is in a tight spot in attic...oh well...
NJ-IEC
Yeah, the 1/2" EMT has a set screw, loosen it and lower the conduit until the box is flush with the bottom of the medallion.
When I lower it, is the counter weight going to be in the way ? Don't remember if it hangs down low enough...
1 - 10 of 10 Posts
