1 - 20 of 26 Posts
Thoughts?
Customer sent photo of a chargepoint they plugged into a 50 amp kiln receptacle we did a year ago, fed from a Homeline 50. Said they weren't sure what amps they set it to. Going to inspect the circuit Tuesday for them, as I've seen a polestar burn up a 60 amp ge and kill a chatger. I feel like the issues with car chargers will be frequent. Already had 2 clients get the red light of death on wall connectors. Interesting.
Pliers Gas Set tool Audio equipment Gadget
Can't Remember
I guess I'd need to know what setting the charger was set to. The early Tesla chargers that went up to 80 amps smoked a couple of my installs. The newer ones have been ok. I don't care for the idea of the latest gen Tesla ones need you to connect to wifi to adjust the charger output. The previous ones had switching for it that I remember. What I really hate is skimpy to no documentation delivered with products and all you get is one of those codes to scan or a link. Don't they realize even in affluent areas, there isn't always wifi or cell service available. The lousy pictograms and poorly translated text is crap.
C10
I agree but those pressure clips do seem to have alot of pressure behind them.
I have noticed the newer ones having more pressure, let us know what you find..that is if there's a visible story on the melt down...
Polarity seems correct, it could be that only a few strands were inserted and the rest bent back as the cable was being pushed in.
They may have set it for 48 even though it's plugged into a 50 amp kiln receptacle. They tried to get me to make them a second invoice a year after install, saying car receptacle not kiln receptacle like the original ironically enough. I told them it was against company policy.
Do these plug into a receptacle already there? It looks like you can order a couple of versions 14-50 or 6-50. Internal wiring should be able to handle any amp setting. Manufacturing defect?
Yes probably. Cheap junk.
Theyre like tinned or soldered ends on the wall plug cord and those come preterminated. The installer puts the car charging cable under pressure clips which are also tinned.
C10
That's right, thanks for kicking around the electrons in my memory. I am now thinking it was the soldering point to the board perhaps..mfr defect
Can't Remember
Most of my experience has been with Tesla. I've wired Porsche and some other off brand someone else provided. I wouldn't know whose to buy if it wasn't Tesla. We have a Tesla and I haven't bothered to put in a wall charger yet because the 120v has been keeping up with my wifes driving. Shes been working from home mostly so the 120v is fine.
1 - 20 of 26 Posts
