1 - 14 of 14 Posts
Part of my job is to inspect electrical panels monthly and there are a lot of them. Removing the cover, checking connections etc.. We had a company come out and use a heat gun to inspect the panels. This thing found breakers that were near the end, loose connections, corrosion on the bus bar. SO does anyone know of a decent heat gun that is under a grand?
Data Tech/Apprentice.
You should probabally look into training and being able to diagnose what you see.
If its warmer then the other breakers then you check it out. How hard can it be?
Assuming your talking about FLIR. You can get alot of false readings depending on the material your measuring ie matt black will show up differently than chrome despite having the same temperature.
I bought a harbor freight (laugh now) fine, but it worked great, it have various
temperatures buttons (12) settings, with cool down.
We heated various PVC in a 4'- 6" piece of PVC, taped one end and rags in other.
We heated the life out of it.... I got so hot we had to use the 8 or 9 setting,
as to not burn the conduit...
The company I used to work for had Ideal HeatSeekers. I liked them.
But I second chewy, go to training and get certified, anyone can take pictures and say look this breaker is red change it. It looks better when the certified guy says it.
Can't Remember
I'd love a PQ analyzer too, but don't think I'd know what to do with what its telling me. Just like any of the high end gadgets, it takes some training and experience to really make the most of it. I have played with thermal cameras and its not something that makes you an instant genius. Neat tool though.
To be fair, I really did picture a company testing a panel with this, and I was really confused:
That's the heat gun I have too and I also assumed that's what he was talking about.
1 - 14 of 14 Posts
