1 - 20 of 49 Posts
· Premium Member
Have to work this weekend around electro paint process tanks. There is dried Phosphate material all over in the area. Anyone have any idea of the basic protective clothing for this type of chemical ?
· Banned
There will be nobody to ask. Plant will not be in operation.
I would think that they have clothing there already for employees.
There is still plenty of time to contact the business before the weekend and ask them what needs to be worn in that area & for them to leave a jump suit/gloves out for you. :thumbsup:
· animal lover /rat bastard
· Premium Member
Discussion Starter · #9 · (Edited)
may need a respirator also?
I hate chemicals:mad:
Yep, and if it's Zinc Phosphate which I think it is for electro dipping, it's also used for rodent poison !
Zinc phosphate is an inorganic chemical compound used as a corrosion resistant coating on metal surfaces either as part of an electroplating process or applied as a primer pigment. Wikipedia
· Banned
Yes, but they are shut down for production so we can work on the weekend. My employer told me he has worked around this for years :whistling2: So he doesn't care, but I do. If I call now I may cause a problem.
it's FLU season ya know [wink wink] :whistling2:
Reactions: dronai
· Senile Member
Pre antidote before hand with hydrofluoracidic acid prep- Drink a glass of tap water and brush your teeth with Crest. That should counteract anything.
So you're asking these guys because you don't trust your employer? ;) I would think a little google research should give you the answer you're looking for. Or you could give the epa a call and see what they say about it.
Been in chemical plants for decades. MSDS sheets will be available and so will experienced safety folks.
Do what they tell you, ask questions, don't look up to see where that drip is coming from, wear a hard hat, chemical goggles, gloves, tyvec suit, etc whatever they wear. Wash your hands before and after taking a leak or scratching your eyes.
I always carried a roll of litmus paper in my pocket (and made my guys do it too) . Toss a bit in a puddle to see if it's safe to work in.
Because you even asked, you'll do fine!
I'd figure a tyvek (depending on how messy stuffs gonna get), goggles and a dust mask.
And remember with all chemical situations, if **** really goes down run like hell up wind. :thumbup: :laughing:
· Premium Member
Discussion Starter · #15 ·
This is in a dried powder form all over the inside of the vessels we will be working in. We wear goggles, and hardhat only. I asked for a disposable suit today.
· Premium Member
Discussion Starter · #16 ·
:laughing: Remember these photo's from last time I was in there ?
· Banned
If you end up dead, no problem?
I agree! :thumbsup:
After everything I've seen & breathed already myself? My dad died from Mesothelioma and that worries me too.
I am very paranoid about chemicals & what gets into my body either breathed or topically absorbed thru the skin. you should be too bro dronai.
I never trust what someone tells me who's goal is to make a buck off me being in those type of environments. I check out the truth for myself.
Reactions: CraigV
1 - 20 of 49 Posts
