1 - 6 of 6 Posts
For multiple fixture control, multiple low voltage CM 6, CM 50, and/or HM 10 Series High Bay sensors and power packs are recommended. For lower mounting height applications, CMR 9 or CMR 10 Series sensors are recommended.
Got it off sensorswitch.com
I appreciate the attempt. ^^^^^^^
Not much info out there on what the letters and numbers mean.....
Picked up 30 from a lighting distributor in Philly, and none of these numbers are on them???????
My search continues
Cheers,
CM - Ceiling Mounted
R - Line Voltage Powered
B - Box/Fixture Mount
CMRB 6 - HIGH BAY 360º SENSOR
FIXTURE MOUNT BOX • LINE VOLTAGE • PASSIVE INFRARED (PIR)
CMRB 9 - STANDARD RANGE 360º SENSOR
CMRB 10 - EXTENDED RANGE 360º SENSOR
6 is for high up (greater than 15ft)
9 is standard for low ceilings
10 is for mounting in low ceilings with a wider sensor range
1 - 6 of 6 Posts
