1 - 20 of 20 Posts
Lately I have been doing some cable connections and was wondering the importance
of "Coax F Terminators", or these guys.....(see photo)
I have a few cable splitters that have extra ports that are not needed.
Should I cap them with these terminators? I have used them outdoors
to keep moisture from going inside the connector port, but are they still important indoors?
Thanks,
Andrew
Hello. A Google search will show you all the technical reasons why a terminating cap works. In my own experience, I use them but I have never cured a problem with them, nor have I started a problem when removing them.
Something more important is the splitter, you said that you have extra ports that are not needed, so your best bet is to use a smaller splitter. The more splits the more signal reduction. You should be able to find a splitter configuration with a maximum of 1 extra port. You can also chain smaller splitters together to get the exact amount.
Thanks. I only have one extra port on my splitters. The building I worked in has 3 apartments, so there is an extra port on all three splitters. Thanks for you input. I figured that it would be a rare to have a terminator make a difference. The way I see it, is that they are cheap insurance and should be used for a proper install. At the very least, you will know that a port on a splitter was intentionally left empty when you see a terminator cap on it.
Thanks again,
Andrew
I've had problems with splitters where there were uncapped ports. The problems usually manifest themselves as a loss of signal strength and/or interference.
They're cheap enough, it can't hurt to use them.
Coffee drinking member
Install an F connector Dummy load and that will help limit loss and ghosting.
A tip, use eBay for CATV equipment. I personally like Antronix splitters and amps, you can find them for a steal. I use PPC compression connectors, sometimes you can find them for as low as 1 cent each, and then they throw in 100 F-81 barrel splices as a bonus!
I don't know if it's CATV or satellite techs selling material off their truck, but all I know if the price is right.
RF
Here in Australia terrestrial television and cable/catv/matv works on 75ohm.
The terminator caps at the start of this post contain a 75 ohm resistor. They serve two purposes, to contain the RF signal (RF doesn't want to be contained on cables anyway) As in stopping the RF signal from escaping from the unused port thus creating losses. And in bigger systems ( matv system) they balance out the system.
This could be different over in your part of the world
Discussion Starter · #18 ·
Thanks StarLo, I have purchased CATV equipment from eBay, and I couldn't agree with you more. Great Stuff. Who on eBay throws in 100 F-81 barrel splices?
1 - 20 of 20 Posts
