1 - 19 of 19 Posts
What are the articles for these answers? Can not seem to find them.
-The common method to measure conductors larger than 4/0 is?
-In the US, the standard for measuring wires is designated by
Petulant Amateur
Poor electrician, excellent bull chitter.
In the US, the standard of measurement is based on the body parts of an ancient British monarch.
Discussion Starter #6
I am asking you how you are looking to measure the conductors. The width? Length? Weight? circular mils?
I don't know. I am not looking to measure them, it is a code prep question. I guess it has to be in the NEC pretty close to word for word as most questions are.
What a bs test question ! not enough info. Look around Article 310 for most conductor tables, and info
110.6 Conductor Sizes. Conductor sizes are expressed in American Wire Gage (AWG) or in circular mils.
MCM is the same as kcmil.
EC
Chapter 9 Table 5 will give wire sizes and their dimensions-- terrible question
Reactions: Bird dog
Hackenschmidt
Does the question say "method to measure" or "unit of measure" - either you confused it when you copied it, or the instructor fumbled when they wrote the question.
Discussion Starter #13
Method.
I found a similar question in another packet and the choices are:
MCM
KC MILS
AWG
C MILS
it then ask for the article.
The standard method to measure wire size is to read the label on the wire.
That’s the first thing that came to me when I read the question.
Th3 bad thing about that question is that its possible to have the correct answer and still be wrong.
In T5 & T8 headings it says AWG or kcmil.
EC
Method.
MCM
KC MILS
AWG
C MILS
MCM was used for years but later got revised to KCM because that was the proper terminology-- the sizes stayed the same...
For example
You used to say 250 mcm and that became 250 kcm
Again Chapter 9 Tables gives this info
Band Member
DIYer Extrodinaire
kcm
AWG
answers in blue
I'm not NEC, but the tables and refs they guys gave you should be good.
1 - 19 of 19 Posts
