1 - 20 of 28 Posts
I had a long talk with a bigshot head inspector a bit back, and he said there will be a time when the code gets so excessive and complex that is going to drive the cost out of control to do anything at affordable levels and it's going to drive electricians to do things underground. Well, I think that time is now. What do you think about his "Nosterdamus" prediction ?
We are getting closer, maybe not today or tomorrow but in a short period of time the CMP will be in full control by the manufacturers. I can see the highest bidder getting there proposal put in.
As for the AFCIs I am already underground with them and I think a lot of guys are as well.
RIP 1959-2015
The code is fine just charge what your worth.
Have you seen the 2014??
So now a legit contractor comes to give an estimate for a panel upgrade and charges $2,000 more (just to cover the cost of the 36 required AFCI's) than the electrician who is willing to do it without a permit and not use the AFCI's.
I give 2 prices when people want a permit. They usually change their mind and want the no permit one. Funny thing is I do the job exactly the same.
200 amp panel change no permit 2014 $1,100.00
Permit $ 2,350.00
Which one will they take?
I haven't seen the '14 yet, but from what I heard ("oh you heard it?"....I know, I know)...but from what I heard, if you're just changing the panel, and you're not extending the branch circuits (I think it's "extending more than 20 feet"), then you don't have to upgrade to AFCI breakers. Is that not correct?
RIP 1959-2015
We are not required to install AFCI's TO do a service upgrade,only new circuits.
Do inspectors ask for AFCI's? I do service upgrades all the time and put in a clause that if the AHJ requires them I will add their cost to the contract, and have yet to be told to install them. I've also never seen an inspector see if one ground rod is 25 ohms or less or ask if I've installed a second one.
animal lover /rat bastard
there is no limit to how extensive any code can get. the procurement rules for some gov't work take up a large bookshelf. a law library takes up a whole building. this thread is cletis.
OSHA is already there.
That is so true If I could thank you more than once I would.
Not always, some inspectors argue Its a modification to existing wiring so it has to be. I think its more of them thinking its a safety enhancement thinking that AFCIs actually do something.
Some do some don't its one of those things that change from town to town county to county. Whats funny is some inspectors will ask for a 2nd rod even if you prove 1 is ok.
fertilizer distrubuter
I have one jurisdiction that requires 2 unless you prove it is less than 25 ohms. It is cheaper for me to add the second than buy the stupid meter.
1 - 20 of 28 Posts
