1 - 20 of 26 Posts
Coffee drinking member
Semi-Ret Electrician said:
I know of a bunch that have been burning for several years in a -40 F freezer. They came from Home Depot but were installed warm and never turned off.
I haven't tried the new LED's in the cold yet.
I think I'll toss one in for the next few days. It's going to be sub-zero for awhile.
99cents said:
Stock up on incandescent A19's. When they run out, buy halogen A19's. I have even seen LED's underperform in cold weather.
I have been burning the halogens here the past few years and like them. I haven't had one burn out yet.
I use whatever is cheap and they start, just takes a while to warm up.
temperature around here is near zero and some arent even starting. Most just warm up but remain dim.
These are in post lights and exterior security lights.
I like ceiling fans & EMT
I just use regular cheap CFLs in any temperature. They start dim but come up to full brightness eventually and I've not lost one prematurely.
There are quartz restrike kits that will work with fluorescent fixtures that have at least a 50W draw.
You mean a vari resistor?
Yes that might work but for us to start selling them they would have to be listed.
The ones I've seen were wire into TV's to enable de-gaussing at start-up.
It would be hard wired into incandescent type circuits to lower the run voltage from 120V to say 110V (and soften the surge) which would greatly extend lamp life, at the expense of lumens, of course.
It would be like running a 130V lamp at 120V. They're starting to get scarce and pricey.
Theres used to be little "buttons" sold that you put in the bottom of the lampholder before you install the bulb that did just that. They looked like the flasher buttons, but they were a resistor type of thing.
1 - 20 of 26 Posts
