AFCI breakers have some GFI protection built in but it is not GFCI protection as the current levels are up to 30 ma instead of the 6ma trip for GFCI.Does any manufacturer make them? Did a google search and nothing
Yes I was reading that.. I happened to run one lighting circuit for a small second floor addition that includes a bathroom and there is a light over shower and a exhaust fan in bathroom that inspector will probably want GFI protection so was hoping to kill two birds with one stoneMshea said:AFCI breakers have some GFI protection built in but it is not GFCI protection as the current levels are up to 30 ma instead of the 6ma trip for GFCI. I don't think there is an AFCI/GFCI combination out there.
or you could install a dead front gfci at the switch boxYes I was reading that.. I happened to run one lighting circuit for a small second floor addition that includes a bathroom and there is a light over shower and a exhaust fan in bathroom that inspector will probably want GFI protection so was hoping to kill two birds with one stoneI will probably just run another home run for bath lighting circuit and tie together in panel and if he wants fan and light gfi protected will separate in panel
I could but the first box is a single gang box so would have to use a combination gfi/switch. Do they make a dead front combo switch device? I guess I could make it a 2 gang but that looks like crapdrspec said:or you could install a dead front gfci at the switch box
Cut it in below the switch box?I could but the first box is a single gang box so would have to use a combination gfi/switch. Do they make a dead front combo switch device? I guess I could make it a 2 gang but that looks like crap
Or cut in a box for the dead front elsewhereI could but the first box is a single gang box so would have to use a combination gfi/switch. Do they make a dead front combo switch device? I guess I could make it a 2 gang but that looks like crap
Another option is put the bath light & fan on the bathroom circuit.Yes I was reading that.. I happened to run one lighting circuit for a small second floor addition that includes a bathroom and there is a light over shower and a exhaust fan in bathroom that inspector will probably want GFI protection so was hoping to kill two birds with one stoneI will probably just run another home run for bath lighting circuit and tie together in panel and if he wants fan and light gfi protected will separate in panel
Yea that is no longer a option because I already wired switches and lights in 14. I may be able to hide a dead face behind toilet where it can not be seen easily but was just hoping they made a combo AFCI/GFCI breaker which would of been the perfect solutionRoger123 said:Another option is put the bath light & fan on the bathroom circuit.
This guy is a contractor so would probably notice and ask why there is a extra space that does nothingdrspec said:Or cut in a box for the dead front elsewhere We as electricians are the only ones to notice How many houses have you see that is prewired for speakers and volume controls or security and have blank covers everywhere?
OK, then put a GFCI receptacle just outside your panel and run your lighting circuit through it. Make that a dead front recpt.Yea that is no longer a option because I already wired switches and lights in 14. I may be able to hide a dead face behind toilet where it can not be seen easily but was just hoping they made a combo AFCI/GFCI breaker which would of been the perfect solution
That's probably what I'll doRoger123 said:OK, then put a GFCI receptacle just outside your panel and run your lighting circuit through it.
yeah, just like they have afci outlets readily available:whistling2:The manufactures are developing a Dual rated AFCI/GFCI circuit breaker.
Supposed to be out soon as the 2014 code added kitchens and laundry rooms to the AFCI list, along with requiring all receptacles in laundry areas to be GFCI
Does your friend know when I'll be able to get QO gfi breakers for the new panels with the "plug on neutral"?123electric said:SQD QO does but you have to have a friend who is a distributor to be able to get your hands on that sample. You did not hear that from me, shhh![]()
