1 - 9 of 9 Posts
EL01
Yep, looks like overheating to me.
DFCI breakers are designed to catch both, Ground Faults & Arc Faults from what I understand...not to mention overcurrent.
So...protect wire (overcurrent), protect people (ground fault), & protection against fires (arc fault)
Industrial Electrician, Class A
Forgot to mention it tripped on arc fault two nights one day apart,...
Op's header said combination so I'm guessing no gfci protection. Unless it was either one of the breakers that has undeclared gfci in it
1 - 9 of 9 Posts
