You get there, half the lighting works the other half, they say, comes on and off by themselves. You open up the panel, remove the main breaker, it is stuck to the bus bar, you chop it out so that you replace it, the bus bar is all eaten out from arcing, you can not and should not install the new breaker and pack your tools, write a service call invoice and say 'good night' my day is over, I am all booked for tomorrow, call someone else to change the panel and whatever is necessary!
They could sue you because most of the lighting worked before you set foot in the home. Now nothing works? If you don't want to get sued you have to replace the panel or new service totally at your own expence! It did not happen to me but I know somebody that it did.
Any comments?
Any comments?
