1 - 9 of 9 Posts
Is there a conduit carrier that has top access?
The common conduit carrier only has front access, so shorter pipes are hard to access.
A conduit carrier with top access would be better in order to see what you have and to grab smaller pieces.
Is there a manufacturer that makes this type of carrier, or do I have to have it custom built by a metal worker?
I ty-rap the shorter pieces to the full size conduit to keep it accessible. Don't cut off the ty-rap tail, makes it easy to find shorter pieces.
Coffee drinking member
My torpedo is inside my van. It's 8'.. When I run more I buy only what I need.
If anybody puts a cut piece of conduit in my carrier they are fired! Mine opens to the back of the truck, not front. I have not seen one open to the front in fact. How on earth will you be able to see inside the top of a conduit carrier anyway? And I agree, anything under 10' gets tossed in the truck or chucked in the dumpster.
1 - 9 of 9 Posts
