No problems whatsoever.
Use a transformer 110 to 230 volts at the appropriate Kva rating. No need to use a GFI unless you need to. Earthing/grounding is just the same ,
. As for 60Hz/50Hz. It makes no difference with this type of equipment.
Just be careful to correctly connect the different coloured wires to the US supply.
Blue or Black --- Neutral
Brown or Red .... Live
Green/Yellow ..... Earth
