Consumer Unit Location
2964 Views 9 Replies 4 Participants Last post by  general matters
Please could you let me know what the maximum distance allowed is between the electric meter location and the consumer unit to comply with current regulations?
Stuart
:no:
1 - 10 of 10 Posts
I think it's 5' inside the house without a disconnect. Really no limit if you run outside.
I need about 8m from the meter before a suitable location for the consumer unit!
Firstly, can this be done? would it need a sub-main? what extra expense is involved in doing it this way ££?
Thanks
Stuart
It can be done. You need a switch fuse at the meter head and a sub main circuit of 16mm or 25mm from this to your Consumer Unit.
Costs . I don't know.
FRank
Frank,
We are going to use a built in wall box, will the switch fuse be located in the meter box, or will it be located remotely adjacent on the wall?
Kind regards,
Stuart
I suspect the Supply Co will not let you use their meter box to fit your switch fuse isolator. You will need to fit a another box adjacent.
1 - 10 of 10 Posts
