1 - 12 of 12 Posts
Has anyone heard the rule that if there is more than 4 contactors in a box it has to be CSA approved as a control box. Can not recall anything in the code book regarding this.
Got busted eh?
Manitoba Hydro 2012 Electrical Bylaw
Item # 5 rule 2-024
I'm not sure, but I think the City follows the same rule, but it's not stated in the Technical Interpretations.
The way I was told that the rule means a maximum of 4 contacts in a box, and anything other than that,requires a Dept of Labour ( Office of the Fire Commissioner) inspection or label.
That means switches, pilot lights etc.
Nope not busted, going to run into a situation where I am going to need to run a bunch of kitchen equipment through a contactor and would love to put them in a 18x18 above the panel.
So the rules say maximum 4 contactors or relays.
Do they mean 4 set of contacts or could I put in 4 8 pole contactors in and be good.
Those requirements they list, is that for when your using a normal box with 4 or less contactors.
Check with whichever inspector is looking after your area.
The way the MB Hydro inspector explained it to me, was, no more than 4 contacts. So any combination of contactors, just as long there weren't more than 4 poles.
But as I said earlier, its only detailed in the Hydro bylaws, not COW's, and I haven\t been in the situation of putting together a box with more than 1 relay.
Size is important too, as one of the concerns, is heat dissipation. Hence the restriction on the number of poles.
https://www.hydro.mb.ca/customer_services/permits_and_inspections/electrical/electrical_code.pdf
If that is the case, I better start thinking of another way to do it. Don't really like the idea of 5 or 6 boxes just for contactors.
well this may a little more expensive, but you surely have control panel companys that have CSA and they can make the panel for you and have it csa listed
There is two separate kitchens, one kitchen has 8 or 9 circuits. The second kitchen has roughly the same.
They make 12 circuit contactors with their own enclosure.
Don't know if it will help you or not.
Discussion Starter · #11 ·
Two kitchens, two separate fire suppression systems. When fire suppression goes off it only turns off in the kitchen where fire suppression is pulled.
If the 'more then 4 contactors in a JB' effects you, you could have two big contactors turning off two small pony panels. Each Pony Panel would feed each kitchen.
1 - 12 of 12 Posts
