1 - 14 of 14 Posts
I'm interested in writing for my contractors license in Manitoba. I was just wondering if its similar to the red seal? Or based more on the by laws? Any good books I should grab for a review? I wrote my red seal in the summer so most of the schooling Is fresh in my mind. Any help would be appreciated thanks guys
· RIP 1959-2015
I thought the Red Seal gave you that.
Rochsolid said:
I can pull permits in the areas that Manitoba hydro have jurisdiction, but I cannot do work "legally" within the city limits on my own without a contractors license(at least to my knowledge)
You need a red seal and a class H license to work legally in MB. A contractors license allows you to pull permits within the city of Winnipeg.
In B.C. it is illegal for any persons to do electrical work for others without a valid contractors licence. Also requires a test and a 10,000.00 bond put up before you are issued a licence.We have three classes of licence also.A,B and C.I didn't realize it is so different in other provinces.
· Electrical Contractor
The Red Seal is an inter-provincial license which says that you are a qualified JM. Having a Red Seal, gives the ability to work in every province (except Quebec). Basically, one applies for and receives a new provincial license for the appropriate province.
In some jurisdictions, a separate "contractors/masters" license is required to pull permits. In other areas, your JM license is all that is required.
For example, with the exception of the City of Winnipeg, a JM can pull a permit for any installation in the Province of Manitoba. I believe, in Sask, your JM license allows permits in the entire province.
In Alberta, and Ontario, you have to get a Masters license, which is a separate exam.
What are the classes?
· Senior Member
Exam Kit: Class A FSR Unlimited voltage, unlimited current
Class A (ARD) FSR A FSR for Alberta Certified Master Electrician
Class B FSR 750 volts or less, unlimited current Class C FSR 240 volts, 200 amps or less, single phase
Class FE FSR Full Entertainment
Class IN FSR Instrument Mechanic
Class LE FSR Limited Entertainment
Class LI FSR Line Technician
Class LO FSR Low Energy
Class PV FSR Solar Photovoltaic
Class RE FSR Refrigeration
Class SA FSR Security Alarm
Class UR FSR Underground Raceway
Class WW FSR Water Well
there are cases where a permit is not required, though, making it legal without a contractors license. here's the link to the appropriate safety regulations, but a TL;DR is that any 120v plugs, switches, ballasts, thermostats, O/C devices, (and even fuses up to 750v!) are allowed to be replaced without a permit.
Does that really mean you don't have to be a contractor or just not need a permit.That would imply then that any handyman or cowboy could do those jobs.Just because you don't need a permit doesn't mean you don't have to be a contractor to do those jobs.
1 - 14 of 14 Posts
