PLEASE APPLY HERE:
Indeed Job Posting
Or
Linkedin Job Posting
LEL Critical, a division of LEL International, is looking for an experienced
Industrial Controls Electrician at our newly renovated (climate controlled) Spartanburg, SC facility. We are a small, fast-growing company that can offer upward mobility as we continue to experience growth. Our culture is family-focused which translates to an 8-5, Monday through Friday schedule. Not on call, no travel.
As our
Industrial Controls Electrician, you will work on our design-build team for our industrial generator (500 kW+) systems. You will have creative freedom with laying out the control panel and building cabinets for various needs. We have in-house metal fabricators to assist.
You will be successful in this role if you possess prior controls experience. You are a team player and eager to assist when needed, as well as work independently with limited supervision.
Core Competencies Needed
- Must be proficient working with control panels
- Well rounded knowledge of PLCs, VFDs, Motors and Controls
- Design and layout switchgear cabinets, buss duct, CB buss bar for connections.
- Problem solves simple to complex control applications for alarming and engine controls.
- Familiar with circuit breaker sizing and installations.
- Ability to calculate proper size electrical cables based on load, and NEC table 310.
- Systems integration
- Familiar with parallel operations and understands the principles to parallel power systems.
Highly Desired Skills
- Prior knowledge of control systems such as Cummins Power Command, Caterpillar EMCP.
- PLC, HMI system use and operation.
- 4-20 ma , 0-90 ohm, sensors and connecting to form A,B and C contacts along with digital input and output.
- Rockwell Automation, Siemens, ABBABB familiarity
