Today I was working on a service upgrade on a house which involved relocating the panel. It was an old Nema 1 Bulldog panel which had been outside under a porch and had a number of romex circuits run outside under the porch as well so they needed to be replaced.
The range was fed with a 10-3 that was on a 40A breaker and was about an 80' run. When I was talking with them about it needing to be replaced I mentioned that it has probably hasn't caused them serious issues is because they don't often run the whole range at once. The wife then told me that during canning season she may actually have burners and the stove running at the same time. She then said that it seemed that it didn't heat as fast or as well when she did that.
That got me to thinking that perhaps because it is all resistive loads, it would self regulate the current due to voltage drop, and actually keep itself from burning up the wire. Not that I think its a good idea, but it is an intriguing thought. It has been operating that way for probably over 20 years and I did not see any obvious insulation damage on the wire.
