Cute, real friggin cute guys
1093 Views 18 Replies 10 Participants Last post by  splatz
Finally figured out how this pipe had 8 wires in the building and only 2 at the valve vault.
Reactions: 2
1 - 19 of 19 Posts
That sucks.
Everytime I come across one of those surprises, there’s never any real satisfaction in finding it, only irritation.
Reactions: 5
At least you figured it out.
Meh, would've been the first place I looked 🤣
  • Haha
Reactions: 4
I found this one pretty entertaining and it just solidified my decision just to repipe this vault.
Funniest one i have found recently is 4 white 90's acting as a gas seal/plumbers U trap between the lift station and the panel.
This same building has a piece of liquid tight glued into pvc fittings.
Now that’s funny. I like seeing that. :ROFLMAO: You can’t even get made at that.
You know how many times I’ve wanted to do this???!!!:ROFLMAO::ROFLMAO::ROFLMAO:
  • Haha
Reactions: 2
Apparently it works. I wouldn't have thought the sizes would work out, but someone figured it out.
  • Love
Yeah, I wouldn’t have thought about it either. My buddy showed me that trick with a devious smile on his face.
Anything except EMT. It's all pipe sizes. Sure they're white instead of gray...
Correct me if I may be wrong, but I think all pipe up to and including 2" is an o.d. dimension, after 2" its an i.d. dimension.
  • Haha
The trade size designation is not the actual I.D. but it's close. Like most things the spec has a tolerance.
Notice, until you get to 2", none of the sizes are nice even sizes at all. And above 6" the OD is +3/4".
It is best to never think of "OD" at all when dealing with pipe.
It is not "_ OD pipe", it is just "_ pipe".
That used to be common practice around here. Then one day the inspectors challenged the practice and nobody wanted to fight them. :)
Personally, if it's strapped secure, I don't see anything wrong with it, but I was taught by hacks. (no not hax :) )
I always thought pipe was id and tube was od. Emt is tube so it made sense to me
Reactions: 2
I'm sorry, but if it makes sense to you, you don't really understand it. :p
It just is.
Pretty sure we pulled some 10's and 16's through a plumbing elbow this week. Old wire came out in two pieces with a mini ex lol
Carlon used to have it in their listed instructions for their Carflex but i think it was removed finally.
  • Helpful
Reactions: 3
That used to be common practice around here. Then one day the inspectors challenged the practice and nobody wanted to fight them. :) Personally, if it's strapped secure, I don't see anything wrong with it, but I was taught by hacks.
I heard about a guy that met a real hack that might glue sealtight into PVC fittings under the right conditions. He said it may not be in the instructions but it's a pretty strong connection. Somehow it's legal with ENT but not with LFNC.
Wouldn't you say there's a lot of legal things that are a lot more hack?
Reactions: 4
1 - 19 of 19 Posts
