It's been a while since I've dealt with an SVX9000, but somewhere in the parameter menu/manual it will have a parameter that shows the 4-20mA value on whatever analog input you're using. Take a look and see what it's reading.
I would verify your speed reference is set to the analog input you're using.
Dip switches, if it has them, are set to 4-20mA, not 0-10v.
Verify your speed reference isn't inverting the analog input, unless that's what you want.
Verify your minimum speed isn't set to 60hz.
Make sure your drive is using the correct source, are you in hand, auto, local, remote, etc like you should be?
That's all I got just thinking off the top of my head...
