1 - 20 of 25 Posts
They sell tubing cutters (greenlee 8600) for emt in the electrical tool section at (some) home depots next to all the Klein stuff. Someone said the tubing cutters with the little wheel that scores the emt is an east coast thing but I don't know. All I know is that cutter is the best option for cutting emt with wires in it without damaging the wires
DO NOT buy the tubing cutter in the electrical section. Its big, bulky, and Wayyy overpriced. Get the one that Shock showed in the plumbing section. The small one can cut up to 1" emt just fine and can fit in hard to reach spots (like in a wall).
You will have sharp edges you have to deal with afterwards. Everybody has a different method of cleaning them. I recommend (after cutting the pipe) to slip something over the wires into the pipe (to protect the wires) and then cleaning it out with a small file or the side of a flat head. After its cleaned, I recommend wrapping a few layers of tape around the wire in the spot you cut.
Rest In Peace
The plumber left me a tubing cutter near the bottom plate at the shower on an addition we roughed in.
The greenlee cutter is like $50 and the cutting wheels only score and don't cut all the way through and are designed to produce an edge that doesn't need to be reamed. I haven't seen one in action yet but I wouldn't mind finding out if the device lived up to its promises.
If you have access to the end of the conduit where the wires are coming out another option would be to go into your automobile and look on the floor for some plastic soda bottles (or try the garbage) and cut out the flat side parts of the bottles and use that material to wrap around the wires then push into the conduit to protect the wires while cutting around the tubing using a hacksaw or a keyhole saw that uses metal cutting blades from a sawsall.
It makes a better hammer then a cutter.
1 - 20 of 25 Posts
