Anything is possible. How long is the trench and how many rebars would be cut?If a trench about 18” wide has been made in a concrete floor, what happens if you cut out rebar across that span? Is there a chance that the floor could sink?
:thumbup:The concrete was opened up before I was called in. Thanks, guys. I will figure out a plan B and keep the rebar intact.
Cut 12” out of the middle, do your work. Buy enough #3s or #5s to cut 9 pieces 18” long. Tie wire 3 of them around each of the 6” cut rebar stubs nice and tight 120 degrees apart. Place the cut pieces in the middle if you want to hide the evidence. Pour concrete. :vs_cool:If a trench about 18” wide has been made in a concrete floor, what happens if you cut out rebar across that span? Is there a chance that the floor could sink?
The idiot shouldn’t have cut a footer like that. There is a formula to fix that and cutting the rebar isn’t going to matter. They will have to dig under it a certain amount on each side and pour a kind of platform and tie them together with rebar somehow. Or maybe a piling if that can be dug.The concrete was opened up before I was called in. Thanks, guys. I will figure out a plan B and keep the rebar intact.
Nope.The idiot shouldn’t have cut a footer like that. There is a formula to fix that and cutting the rebar isn’t going to matter. They will have to dig under it a certain amount on each side and pour a kind of platform and tie them together with rebar somehow. Or maybe a piling if that can be dug.
It’s a real problem. I hope your guys didn’t do it.:sad:
It looks more like a footer to me, interesting product.IF it is a structural slab, then the engineer may require rebar couplers.
