Yes, it's exposed so it needs to be smooth. And it needs to be SS.sparky970 said:Any reason you can't use all thread?
Is it a job spec to be smooth? If you have a lot to thread, get the right tools or it will fight you the entire time. What about PVC coated SS?Yes, it's exposed so it needs to be smooth. And it needs to be SS.
Would it be an option to use all-thread and sleeve it with a stainless tube?Yes, it's exposed so it needs to be smooth. And it needs to be SS.
How many pieces are you going to thread?I need to thread a 3/8 stainless steel rod. I have a Snap-on tap & die set but have never tried SS. Anyone have some opinions on this?
If the rod is to be threaded then bent for placement, won't you need a two sided cotter pin type of application on one end?This is a rod that is used as a guard. It will be 30 inches long then bent both ends 3 inches long. Each end needs 1 inch threads to attach it. I need two of them, so 4 threads. I don't know if the dies are rated for SS. I'll look at the set.
I would thread after the rod has been bent. It will be fastened with nuts on the inside of the equipment. This is a food prep location. That's why it's SS and smooth.CADPoint said:If the rod is to be threaded then bent for placement, won't you need a two sided cotter pin type of application on one end?
