1 - 2 of 2 Posts
Ax grinder
What year code are you looking at?
Table 430.52 Gives you the maximum rating of motor branch-circuit short circuit and ground fault protectived devices, if you look at the last line in the table it has the values for DC motors. Table 430-152 in the 1978 NEC is very similar to table 430.52 of the 2005 NEC. The 1978 NEC is the oldest NEC that I have access to.
Chris
1 - 2 of 2 Posts
