1 - 6 of 6 Posts
Hi
Does any one know if it is possible to reset the engine running time on the Deepsea generator controllers ?
There must be, do you have the manual for the control panel?, if not post the stock number so someone can look it up.
The model is 3110
i even got the Deepsea software, i have gone trough the program already but couldn't find any thing related to (Running time reset), but i found a frimware upgrade tool and i suspect that using this tool also resets the time even though i haven't tried it yet, but this would be a bit messy because you will have to reset all the setting all over again.
Can't Remember
Are you talking accumulated engine run time? Are you moving this controller to a new or different unit?
Can't Remember
I'd say that if the firmware change you are talking about doesn't do it, talk with tech support. On the smaller stuff, I've never heard of being able to reset the hours. Almost like tampering with the odometer in your car. That's not to say it can't be done. The best you may able to do is make note with a label maker someplace noting the hours when the overhaul took place .
1 - 6 of 6 Posts
