1 - 5 of 5 Posts
i want to calculate cable sizing and other protoction for 10 kw motor how can i calculate ?i need a detail of calculation?
i try to wirte a programm for this calculation please help me to find appropriate
refrence.
refrence.
This sort of thing is typically determined by local code requirements, not programs. We cannot help you with that.
i want to know how can i calculate cable sizing-select fuse- with diret conenction and star -deta connection and everything about motorize branche
Right.
As I said, this is not something that is calculated, it is something that is regulated.
This forum is based in the USA. 99.9% of our members are NOT identified as being in Iran (surprisingly, 40 members are! But they don't log on very often).
We (the 99.9%) do not know what your local codes require for wire sizing and protective devices. We also do not deal with metric wire gauges so ampacity of said wire is a completely foreign concept to us, even if we were to take a stab at "calculating" wire sizing.
I can tell you however that the DIFFERENCE in wire size for motor leads going from a DOL starter vs a Star-Delta starter to the motor are that the SD wires can be 58% of the ampacity of the DOL wires, whatever that may be. But then again you need 6 cables instead of 3, so you are actually behind the cost point if that is what your concern is.
1 - 5 of 5 Posts
